message for misdial
Mar 11th, 2009
The setup is like this:
[PSTN]--T1 PRI--[CUCM MGCP G/W]--T1 PRI--[Mitel PBX]--[analog phones]
The issue:
A person has a phone number that they don't realize is long distance, so they dial 9 250 xxx-xxxx. If he does it on a Cisco IP phone, he gets a recording saying that the call cannot be completed as dialed. However, if dialed on a Mitel phone, they get nothing at all, just dead air for about ten seconds, before it starts to do the rapid busy signal sound.
Any idea how this's fixed?
Thanks!
mightyking Thu, 03/12/2009 - 08:53
I would use Dialed Number Analyser from the Serviceablity page to see which route pattern you're matching. If you're using NANP, I would also try putting a "1" after 9 for long distance calls.
MK
xiaoliangyue Thu, 03/12/2009 - 09:03
thanks, MK.
I do have 91 pattern for long distance calls. the problem is that some users forget to put 1 for long distance calls, or they don't realize that the # is a long distance one (same area code with his phone). they would like to hear the message, so they know that they are missing a digit.
carlnewton Thu, 03/12/2009 - 09:09
Are the mitel calls pushed through the call manager? If so, you should still receive this message? If not, your asking the question in the wrong place :) What connects to what and what route should the calls be taking?
