EOL/EOS - get info about a lot of equipment
Mar 11th, 2009
  • Bronze, 100 points or more
I've got one big list of cards and equipment that i would like to check for End Of Life End Of Support info.
Instead of searching for every equipment in www.cisco.com is there anyway better to get this info?
Thanks for your comments and help,
Rgds,
Met.
Overall Rating: 3.5 (2 ratings)
paolo bevilacqua Wed, 03/11/2009 - 12:31
  • Hall of Fame,
    Founding Member
If you cisco AM cares about you, he will collect all the info for you. Of course the hope is that you evenually make orders :)
metalium2007 Wed, 03/11/2009 - 12:56
ah, of course, but.. that is not the way, since it is a lot of equipment for the internal database.
Doubts:
1. Is it necessary to search equipment by equipment on Cisco Site?
2. There is equipment without any announcement. Is it normal, or there always have to be defined dates for EOSale/Support?
Thanks for your help,
Met.
Rob Huffman Wed, 03/11/2009 - 13:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Met,
Thie search through this area isn't too bad :)
http://www.cisco.com/en/US/products/hw/tsd_products_support_end-of-sale_and_end-of-life_products_list.html
Like Paolo nicely noted, it would be nice if your AM or SE would search this out for you ....but (better safe than sorry :)
Cheers!
Rob
metalium2007 Wed, 03/11/2009 - 14:31
Rob -> as always...your answers are really helping!
Thanks!
Best regards,
Met.
