Tacacs+ per vrf
Mar 11th, 2009
Hi all:
I'm trying to configure the featute "tacacs+ per vrf" in order to authenticating with an ACS that a 7600 router learn from a vrf, but it isn't working; checking the ACS, I see that the user do authenticate but I got a messagge "authorization failed" from the router, so I never can login in.
The commands I'm applying on the router are:
aaa group server tacacs+ tacacscisco
server-private 1.1.1.1 key CISCO
ip vrf forwarding CISCO123
ip tacacs source-interface LOOPBACK 0
aaa authentication login default group tacacscisco local
aaa authentication login con_acc group tacacscisco local none
aaa authorization exec default group tacacscisco local
aaa authorization exec con_acc group tacacscisco local if-authenticated
aaa authorization commands 1 default group tacacscisco if-authenticated
aaa authorization commands 15 default group tacacscisco if-authenticated
aaa accounting exec default start-stop group tacacscisco
aaa accounting commands 15 default start-stop group tacacscisco
aaa accounting system default start-stop group tacacscisco
<Loopback 0 is on vrf CISCO123>
I would appreciatte any help !! tks
The IOS version I'm using is 12.2(33)SRB3
drolemc Tue, 03/17/2009 - 10:09
  • Silver, 250 points or more
This is the expected behaviour, since the user is not defined locally, we are getting "Authorization failed" when going into privilege mode. Please define the user locally and try to login.
