Integrate WCS with LMS
Mar 11th, 2009
Is it possible to integrate Cisco WCS with Ciscoworks LMS? We are running WCS 5.2.125.0 and Ciscoworks LMS 3.0.1. We are looking for ways to stop all LWAPP AP's from showing up on the unreachable list during Device Discovery.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 03/11/2009 - 14:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Currently there is no integration between WCS and LMS like there is with WLSE. To keep the LWAPPs from clogging Discovery, you can add their addresses to the exclude filter. You may still see them as unreachable if they are found by Discovery, but Discovery will not waste time trying to query them.
Sven Hruza Wed, 03/11/2009 - 16:50
  • Bronze, 100 points or more
Are they really shown as unreachable?
I thought on my system (LMS 3.1) the unreachable devices are away after I excluded them by a filter.
Joe Clarke Wed, 03/11/2009 - 16:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
On LMS 3.1, no matter how you filter, filtered devices should NOT show up as unreachable.
raindrop18 Thu, 07/08/2010 - 16:08
I have the same problem, did you get any solution. it's hard to exclude by ip because hundereds of them we have and not constant to filter by subnets. is there any othere way somebody achived this.
Thanks.
Joe Clarke Thu, 07/08/2010 - 16:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no integration between LMS and WCS currently, so there is no better way to filter out LWAPPs.  They will still need to be manually excluded via address ranges.
