DDI on CCME
Answered Question
Mar 11th, 2009
Hi team
How Can I configure DDI for CCME
My DDI Range 2303320-29
and me Phone Number 501 -509
Brgds
Correct Answer by Paolo Bevilacqua about 8 years 2 weeks ago
A nitpick: your DP 300 doesn't need port. port is never used for incoming DP.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Wed, 03/11/2009 - 17:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hi there
just make incoing translation profile and apply it to your pots dial-peer
this one take only las three digits
and on each ephon-dn
creat a number with a secondary number
for eaxmple lets say call coming to last three digits 320 should go to extention 501
ephone-dn 1 dual-line
number 501 secondary 320
good luck
if helps Rate
Paolo Bevilacqua Wed, 03/11/2009 - 20:44
  • Hall of Fame,
    Founding Member
There are two methods, dialplan-pattern and translation rules. I recommend the second especially if you have CUE.
voice translation-profile makedid
translate called 10
voice translation-rule 10
rule 1 /230332/ /50/
voice-port x/y/z
translate incoming makedid
Afragoso2009 Thu, 03/12/2009 - 08:27
Dear All
Problem solved
I add
voice translation-rule 506
rule 1 /21/ /501/
rule 2 /22/ /502/
rule 3 /23/ /503/
rule 5 /25/ /505/
voice translation-profile 506
translate called 506
voice-port 0/3/0
translation-profile incoming 506
dial-peer voice 3300 pots
incoming called-number .
direct-inward-dial
port 0/3/0
Correct Answer
Paolo Bevilacqua Thu, 03/12/2009 - 09:18
  • Hall of Fame,
    Founding Member
