X.25 VC
Mar 11th, 2009
I'm starting to get confused with this now. Can anyone who's familiar with X25 advice pls
Once a Virtual Channel (VC) is up, can i safely assume that i can have a maximum of 256 sessions per VC?
Overall Rating: 2.5 (2 ratings)
paolo bevilacqua Wed, 03/11/2009 - 20:46
  • Hall of Fame,
    Founding Member
What do you mean by "session" ? A VC is like a point-to-point link, you can carry any type and amount of IP traffic on it.
echelon360 Wed, 03/11/2009 - 21:06
Maybe i should rephrase this. A VC is established when a call/signal is requested. Hence, what's the maximum no of VCs that can be made? Is this 256?
paolo bevilacqua Wed, 03/11/2009 - 21:15
  • Hall of Fame,
    Founding Member
Per standard, the maximum number of VCs (combined switched and permanent) is 4095, and cisco supports up to that number as well.
echelon360 Wed, 03/11/2009 - 21:27
On a NM-16A/S, if i were to configure all ports for synchronous x25 connectivity. How many VCs can a single port hold?
paolo bevilacqua Wed, 03/11/2009 - 21:32
  • Hall of Fame,
    Founding Member
As mentioned above, 4095.
Note in real world, more than few VCs per port are seldom used.
