Etherchannel help
Mar 11th, 2009
We have 2 C3750 switches trunked together using an Etherchannel (2 trunk links). In the config it doesn't show what type of load-balnce we are using eg scr-mac scr-ip? How can I find this out?
jorge.calvo Wed, 03/11/2009 - 15:47
  • Bronze, 100 points or more
Simply type 'show etherchannel load-balance'
It is set to source-mac by default.
Marwan ALshawi Wed, 03/11/2009 - 17:25
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
the default always src-mac
you can change it useing the following command:
Switch(config)#port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-ip Src IP Addr
src-mac Src Mac Addr
good luck
if helps Rate
