Unity/Domino UM with FAX Integration
boonchin.ng
I have Unity and Domino as Unified Messaging. Now I would like to have fax integration as well. What are the possible solution? Can I use T.37? Is a Fax Server mandatory for te integration?
Thanks.
sopayne
Take a look at this systems requirements list for Unity 5.0: http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/support/5xcusupp.html#wp470007
If you search www.cisco.com with keywords "unity + system requirements" along with the version of Unity you are interested in, you should be able to find details for a different version of Unity.
I hope this helps.
