IPSLA/RTR Command
Mar 11th, 2009
Hi Everybody,
I'm trying to do some testing with IP SLA and Enhanced Object Tracking and came up with a problem with the commands. I am using a 12.4(15)T7. From the track commands, I want to test the reachability of a host using "track 1 rtr 1 reachability" command. However, the rtr command isn't available now and it was already replaced by "ip sla" command. When I looked for "track 1 ip sla" command, it's not there, only track 1 ip route" is there.
My question is, will it work if I create a configuration like "ip sla 1" then apply it as "track 1 rtr 1"? Is that basically the same? Will the IOS treat the rtr as ip sla too? Thanks in advance.
John
Overall Rating: 4 (1 ratings)
