Best practice subnet size for gigabit network access layer
drhodes
Is there a recommended subnet size with respect to layer 2 broadcast domains in a well behaving access layer gigabit network?
I remember reading something about and interpacket delay but am having a hard time finding info on it.
Ta
David
10 Replies 10
andrew.prince
Level 10
Level 10
/24 per broadcast domain is the normal recommendation.
HTH>
Awesome responses!
I am assuming though there are some exceptions, such as the Cisco Wireless LWAPP architecture where the access points create tunnels back from access point to WLC so the WLC becomes the determining point, which then allows for the mobility requirements of wireless?
Well not in all cases, if you have under 254 mobile devices, spread over a campus network - you still only need 1 x /24. Using local switching - all client traffic is tunnled via the LWAPP AP back to the WLC and switched from the WLC onto the LAN.
HTH>
True - I was looking at the cases where there are more then 254 device, which is our case due to iphones, desktops, pdas etc, etc and how we can accommodate them safely (and transparently) without moving to mobility groups.
http://oreilly.com/catalog/802dot112/chapter/ch21.pdf seems to suggest up to 900 hosts per vlan attached to a wlc may be acceptable.
Well in that kind of a case - you should consider:-
1) WLAN for Phones - which I would strongly recommend for it's own QoS policy, WMM, CAC and AP Load Sharing.
2) not having ALL AP's have ALL WLANS - select which WLANS need to be sent to specific areas for specific AP's. i.e you dont want the Cafe WLAN available from the classrooms (campus examples)
3) Create IP Subnets based on equipment types, WLANS.
Bad practise is to bundle all wireless in one WLAN - bad planning and bad security.
HTH>
I strongly agree with Andrew using a single ip subnet for voip wireless phones and PCs is not recommended.
We have made a deployment using WISMs and several client vlans and it is working well.
Hope to help
Giuseppe
With the WLC version 7.0 you can create interface groups and have multiple vlans per WLAN.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b78900.shtml
Leo Laohoo
Have you browsed the Wireless LAN Controller (WLC) Configuration Best Practices (http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080810880.shtml)?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have noted, a /24 often is a good starting point for a maximum subnet size.  Occasionally it's too large, and conversely sometimes it can be pushed larger.  The determinate is broadcast volume.
On something like Cisco's WLC and/or WiSM, you can often safely push client subnets larger than a /24 because there's not the same broadcast issue between wireless clients on the same subnet.  If your have "temporary" wireless clients, you might also want to use a much larger subnet to allow for a larger DHCP pool, as IPs can be tied up, with transitiory clients until their lease expires.  (Of course, you can also decrease the lease time to recover inactive IPs faster.)
Recently, I've been involved in a project where we've been migrating multiple internal Wireless (WLC or WiSM) subnets (all same SSID and security) to a single /22 or /21.  So far, we haven't seen any problems, although rarely more than a couple of hundred active wireless client at anyone time.  Definitely, a little easier to manage.
