I am running v4.1(23). No command accounting is being logged on the acs server. Found a bugid that supplied a workaround, said cmd and system must be in packet. Tried this and it is not working. Is there any other options I can look at.
There is a known bug in the code 4.1.1. Please install patch 5 ( 4.1.1 patch 5) or upgrade it to 4.1.4 to fix it.
~JG
Do rate helpful posts
