track commands
Mar 12th, 2009
Hi all, can anyone tell me what this first command will do ? I have included some of the other config for ref
track 114 ip route 0.0.0.0 0.0.0.0 reachability
interface FastEthernet0/0
description ## ##
ip address 10.119.29.1 255.255.255.0
load-interval 30
duplex auto
speed auto
no cdp enable
standby 114 ip 10.119.29.3
standby 114 preempt
standby 114 authentication test
standby 114 track 114 decrement 50
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Thu, 03/12/2009 - 03:34
  • Hall of Fame,
    Founding Member
Hello Carl,
the idea here is to test ip reachability of the next hop of the default static route.
the rtr object number 114 is then used to change HSRP priority
Hope to help
Giuseppe
adamclarkuk_2 Thu, 03/12/2009 - 03:35
  • Silver, 250 points or more
When your default routes next hop reachability disappears, the priority of HSRP group 114 will be decremented by 50, the default value is 100 so will become 50 in this situation. If your other HSRP peer is greater than 50, he will become he active HSRP neighbor.
manfernandez Fri, 03/18/2011 - 18:54
This will check for the existance of the 0.0.0.0 0.0.0.0 route in the routing table.  If the default route of the device is removed (probably learning it dynamically) it will invoke  HRSP or more specifially decrement the priority by 50.
I just used it today for the first time today.  Very nice feature.
Manny
