FCIP/IVR San extension license question
I have a 9509 with 1 18/4 blade with a SAN extension license connected over FCIP to a 9222i in our DR site. I have 2 servers connected to the 9509 that will be talking to 4 tape drives connected to the 9222i using 4 1g links and tape write acceleration. I planned to use IVR to control what links were in use for specific tape drives since I can't trunk with tape acceleration on. I do not have an enterprise license on the switches.
My understanding from the docs is that IVR is included in the SAN extension license for this type of connectivity. When I enabled IVR for this it started the timer for the grace license and logging license errors.
Am I missing something on how IVR should be enabled for this or on my configuration in relationship to the licensing?
Michael Brown Thu, 03/12/2009 - 07:33
  • Cisco Employee,
Which MDS are you seeing the license timer messages. From what I understand about your setup, I agree that enabling IVR for the FCIP traffic should not start the IVR license expiry counter.
Can you advise what code is on each end, and also paste in the output from 'show license usage'?
I believe that you can port-channel the 4 GE links, and still run tape-accel, if the port-channel mode is 'active' versus 'on' or 'off'.
- Mike
I have only enabled IVR on the 9509. Both switches are running 3.2(3a).
Here is the show license usage from the 9509
Feature Ins Lic Status Expiry Date Comments
Count
FM_SERVER_PKG Yes - In use never -
MAINFRAME_PKG No - Unused -
ENTERPRISE_PKG No - In use Grace 112D 21H
DMM_FOR_SSM_PKG No 0 Unused -
SAN_EXTN_OVER_IP No 0 Unused -
PORT_ACTIVATION_PKG No 0 Unused -
SME_FOR_IPS_184_PKG No 0 Unused -
SAN_EXTN_OVER_IP_18_4 Yes 1 In use never -
SAN_EXTN_OVER_IP_IPS2 No 0 Unused -
SAN_EXTN_OVER_IP_IPS4 No 0 Unused -
10G_PORT_ACTIVATION_PKG No 0 Unused -
STORAGE_SERVICES_ENABLER_PKG No 0 Unused -
Dave
Michael Brown Thu, 03/12/2009 - 13:49
  • Cisco Employee,
Dave,
Need 1 more dislay, now what we know that the Enterprise license is in use...we can see what lines in the MDS configuration are causing the Enterprise license to be invoked. I thought that the show license usage did include what feature triggered it.
show license usage ENTERPRISE_PKG
If the results of this command show the IVR for FCIP is triggering the license, then we need to investigate further and you might want to open a TAC case.
Please post the output from this command.
- Mike
The reason I went with the IVR instead of a port-channel is this tip on page 48-34 in the fabric manager configuration guide:
FCIP tape acceleration does not work if the FCIP port is part of a PortChannel or if there are multiple
paths between the initiator and the target port. Such a configuration might cause either SCSI discovery
failure or broken write or read operations.
Michael Brown Thu, 03/12/2009 - 20:47
  • Cisco Employee,
f your IVR configuration is only between VSANs in the FCIP arena, and the FC arena, and there are no FC to FC VSANs, then there is a bug.
If any of the FC are IVR'd with other VSANs in the FC arena, then the SAN ext license does not cover the config.
Are their 2 VSANs in the 9509 that are both FC only, in the IVR topology?
If you have 2 FC VSANs, and 1 FCIP VSAN in the IVR topology, you invoke the Enterprise license since there can only be 1 IVR topology.
I recommend a transit VSAN for the FCIP link. On each end IVR between the FC VSAN and the transit VSAN.
The IVR toiplpogy:
VSAN A---MDS1--transit VSANy---MDS2---VSAN B
VSAN A configured only in MDS1
VSAN B configured only in MDS2
VSAN-y configure in both
IVR topology
MDS1 VSAN A and y
MDS2 VSAN B and y
VSAN y is only the FCIP link
This config should not invoke the Enterprise license.
- Mike
Thanks.
Sounds like I made the mistake of putting my tape drives on the transport VSAN's I created on the remote switch. I will try moving those into a different VSAN on the remote end and enable IVR on the remote switch to handle that. If that doesn't work I will open a case.
Thanks for the help.
Dave
Trending Topics: Storage Networking
