What triggers the prompt for memory test during boot up of WLC.
Mar 12th, 2009
I have a controller that sometimes does and sometimes doesn't prompt for memory test at boot up. What triggers the prompt for memory test at boot up?
tomathur Thu, 03/12/2009 - 05:52
The WLC is 4402 and the software version is 4.2.176.0
Leo Laohoo Thu, 03/12/2009 - 16:15
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Have you tried upgrading your bootstrap firmware?
tomathur Fri, 03/13/2009 - 05:33
No, I haven't tried upgrading the software.
tomathur Fri, 03/13/2009 - 07:37
Every time I boot up the WLC it gets stuck at memory test and asks to console to move forward.The bootstrap version is 4.2.112.0. Can we bypass the memory test?
Leo Laohoo Sun, 03/15/2009 - 15:34
  • Hall of Fame,
    2017 LAN, Wireless
I've never seen this before! I have experience with this firmware and bootstrap but your WLC is acting strange.
Try upgradint the firmware (bootstrap is fine) and see if this happens.
If you can't upgrade the firmware because of this memory check sequence, reboot/reload the WLC and during the bootup, interrupt the bootup sequence (by typeing the ESC key) and you can use the manual firware upgrade option.
hleschin Tue, 03/24/2009 - 05:05
We have the same behaviour with a 4402 controller.
After a software upgrade from 4.2.130.0 to 4.2.176.0 the controller didn't reboot automaticly during the first restart with the new software. I connected via console and saw this message:
Airespace 4200 Wireless LAN Switch Board - Memory Test
Invalid Option...Press any key to continue
1. Restricted [4kB per MB]
2. Entire Range [512M]
3. EXIT
Then I choosed option <3 Exit> and the controller started correct.
Hendrik
Leo Laohoo Tue, 03/24/2009 - 14:08
  • Hall of Fame,
    2017 LAN, Wireless
Hi Hendrik,
I've tested by upgrading the firmware (and bootstrap) on two WLC from v3 to v5.2 firmware and I've never seen before!
Have you tried upgrading the bootstrap too?
hleschin Wed, 03/25/2009 - 04:54
No, I didn't upgrade the bootstrap. Is it necessary ?
Or could it be a problem that we have a terminal server connected to the console port ?
Hendrik
Leo Laohoo Wed, 03/25/2009 - 15:51
  • Hall of Fame,
    2017 LAN, Wireless
There are some firmware that won't work until the bootstrap has been upgraded. The bootstrap can sometimes contain emergency patches.
It would not have anything to do with the terminal server.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
