cisco24x7 Thu, 03/12/2009 - 05:54
I normally set mine to "logging buffered 1024000 debugging". It is more than adequated in most situations.
cisco_lite Thu, 03/12/2009 - 09:03
Isn't it an overkill to keep the level at debugging at all times.
adamclarkuk_2 Thu, 03/12/2009 - 09:06
No not really, but it depends on he device you have and you resources available to you.
I have very busy 6500 switches with the following :-
logging buffered 250000 debugging
cisco_lite Thu, 03/12/2009 - 10:38
With 250KB on busy switches, how many hours old log messages can you find ?
