Cisco 851w and Linksys WPS54G printserver
Mar 12th, 2009
Recently i bought a Cisco 851W to replace a Linksys router for a customer.
The wireless connection between the router and printserver were fine before i replaced the linksys with a Cisco. But when i implemented the Cisco router things started to go wrong.
The wireless connection with the print server drops multiple times per day and requires a reboot from both the router and printserver to get it back online.
Here's the config that matters on the Cisco 851W:
dot11 ssid *
vlan 1
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid optional
wpa-psk ascii 0 *
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid *
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
bridge-group 1
interface BVI1
ip nat inside
no ip route-cache cef
no ip route-cache
Any help is greatly appreciated.
Thank you in advance!
Ron Aarts
Cisco Engineer Neon-networking
Scott Fella Thu, 03/12/2009 - 07:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Since the printserver is 802.1g, try to disable 1.0, 2.0, 5.5 and 11.0 and set the others to basic. You can also try to disable shor preamble on the interface Dot11Radio0.1 no preamble-short.
Maybe also update the printserver to the latest firmware.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
