Unable to connecto 3750 with Cisco Network Assistant using https
I have multiple 3750's and have been able in the past to connect to them using CNA with https. We are using Radius and have https enabled on all 3750's. I can connect via putty using ssh successfully. But when trying to connect to some of the 3750's it fails with unable to connect. Any ideas on what I can check or where?
I have verified the https settings on both a 3750 I can connect to with https and one I cannot connect to with https they are identical in the config and status.
Chris
Yudong Wu Thu, 03/12/2009 - 13:43
  • Gold, 750 points or more
Did you generate crypto key?
crypto key generate rsa
Yudong Wu Thu, 03/12/2009 - 14:00
Could you try:
1. disable https and then re-enable it.
2. Use browser to try https connection.
3. post config from both working and not-working swtich.
4. is there IOS version diff between them?
5. Do a packet sniffer to see in which step HTTPS connection is failed.
