SPA3102 provisioning parameters names for Static DHCP leasing
edugodoy.o
I'm preparing a SPA3102 provisioning script and I used as reference the sample file generated by SPC (V5.1.17).
Most of the parameters I need to change are there however some of them are not in the sample file and I can't find a complete parameter reference document.
I'm trying to include static DHCP leasing in the router part however I don't know the parameter names to write to the script.
Does anyone know the script parameter names for static DHCP leasing ? Is there any reference document for SPC?
Thanks in advance,
Eduardo
Alberto Montilla
Dear Eduardo;
Thanks for your question, will check it and provide you a response shortly.
Alberto
Hi Eduardo;
Unfortunately, the reason why these parameters are not in the SPC profile is because they are not remote provisionable, as they are considered user parameters that depends on specific devices and network parameters. You can configure them via the web user interface only.
Alberto
Nevermind, I thought I had something to add and cannot determine how to delete my post
