CSM sticky limitations
Mar 12th, 2009
I have a couple of CSMs in my ServerFarm Distribution Layer and am hoping someone could advise and help me, if possible.
If I have a vserver with "sticky" applied and with a url policy applied in addition to a default serverfarm. Is there a way to force the CSM to make a load balance decision after an initial decision gets made and entered into the sticky table???
Note: The policy points to different reals than the default serverfarm.
With the "sticky" command applied to the vserver and a user comes in (1st time), they are processed either by the policy or by the default serverfarm (based on url) and are load balanced and entered into the sticky table. Everything works. However, if they come back in a 2nd time and need to be load balanced by the opposite process, (by policy or by default serverfarm this time), the CSM never processes it because the user is already in the sticky table. The CSM will not make a load balancing decision to other reals if the user is already in the sticky table from a previous load
balancing decision.
Is there any way the CSM can do this?? Or is the CSM limited for this type of
requirement??
Note: I cannot change the host name portion of my url.
Thanks for your help. I greatly appreciate it.
Tony
Gilles Dufour Tue, 03/17/2009 - 05:54
  • Cisco Employee,
We will need to see your config - policy and sticky.
I'm not sure to understand how you created this.
The CSM will normally parse the policy sequentially, and when it finds a match statement, it will use the sticky method or serverfarm configured.
If no match, it goes to the next policy.
Maybe all you need to do is configure different sticky group for each policy.
ie:
map Host1 header
match protocol http header Host header-value ...
map Host2 header
sticky 1 ......
sticky 2 ......
policy P1
header-map Host1
sticky-group 1
policy P2
header-map Host2
sticky-group 2
Gilles.
