UCCE 6.0 to 7.0 Upgrade - PG can't connect to router
Mar 12th, 2009
I upgraded the Side A Rogger to 7.2(7) and changed the PG Setup to use the new server ip addresses (tech refresh upgrade) but the PG can't connect to the Router. I can ping both ways between the Router and PG. Wondering if anyone else has run into this or have any ideas for me? Thanks
Chris Deren Sat, 03/14/2009 - 10:22
What did you do with the old PGs? Are they offline? Did you use the same logical IDs and PIMs for the new PGs? What errors do you see in the logs?
dchumbley Mon, 03/16/2009 - 20:25
It turned out to be an issue when the 7.0 Instance was added to the new domain it was added as Instance 1 instead of 0 so the Router and PG were talking on different ports.
