CallManager Attendant Console
Answered Question
Console ver. 5.1(1), Server Ver. 5.1(2). The line state for all directory numbers is unknown(?)in the directory window on this one attendant console. On another attendant console(different workstation same network)the line status is showing correct for all lines. Tried uninstalling and reinstalling but got the same result???
Correct Answer by Jaime Valencia about 8 years 3 months ago
check for FWs, antivirus or anything extra on that computer that could block communication
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 03/12/2009 - 09:33
  • Cisco Employee,
  • Hall of Fame,
    2011
java
