ASA 5510
Hello all. I am totally stuck and need some help. I have an ASA 5510 and i had a static inside,outside statment that i needed to change. Actually had to change the ip address of the inside box. I have made the change and know I or the vendor can access the box. I can ping it from the firewall and all access rules are the change except for the change of the ip address. If I look at the xlate it is all pointed in the write direction. Could someone help?
Jon Marshall Thu, 03/12/2009 - 12:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jeffrey
Could you post the running config of the ASA together with the IP address of the box on the inside.
Jon
robertson.michael Fri, 03/13/2009 - 12:26
  • Silver, 250 points or more
In addition to the information requested by Jon, the output of 'show xlate debug' will also help us troubleshoot this issue.
-Mike
