3750s and Sun T5240 connectivity
Mar 12th, 2009
We are having issues with the IP-0 interface on the Sun T5240. I have a total of 4 Sun boxes. Two of them are on one vlan. No problems there.
The other two servers (which all have 5 interfaces on the nic) are going to two different vlans across 2 different switches.
The issue we're having is that the IP-0 interface is responding to pings and ssh connectivity intermittently.
I'm not sure if their configuration is good, but the IP-0 interface has 3 virtual IPs assigned to them across one wire. If two of the IPs are responding and one is responding intermittently, is there something that may reside with the server (Solaris 10) or is there something that needs to be done on the switch?
I would think that if the switch was the issue, that you wouldn't get access to that ip at anytime.
I have tried several things such as hardcoding a static mac-address-table entry with as well as a static arp. Still doesn't give us solid connectivity.
Any thoughts or has anyone run into any issues with these Sun boxes?
