ASA 5510 Issue(inside network ddos traffic)
Mar 12th, 2009
We installed the ASA 5510 in our core network.
I installed Desktop insid ASA 5510(inside), outside is Core Switch
the diagram like below
Desktop(attacker) -- ASA(Transparent) -- Core Switch.
the desktop's default-gateway is Core Switch.
when We lunched the DDos Attack from desktop to victim server located core secure zone, the ASA didn't forward ddos traffic,
I found the count TX/RX pps rate equal on ASA, Why This Issue happen?
our purpose is that the ASA must forward ddos traffic from inside to outside victim server.
In my think, the ASA filterted ddos traffic from inside host desktop.
I disabled inspection(global_policy), but no effect.
What function did ASA do so that?
I should forward ddos traffic from inside attack to outside victim server.
the total topology like below
attacker -- (in) asa (out) -- core -- victim.
this is test bed.
robertson.michael Fri, 03/13/2009 - 12:32
Hi Seungyeop,
You can find the reason that the ASA is dropping the traffic by following these steps:
1. Setup an ASP drop capture:
ASA(config)# capture drop type asp-drop all
2. Clear the ASP drop counters:
ASA# clear asp-drop
3. Initiate the traffic
4. Check the ASP drop counters:
ASA# show asp-drop
5. Check to see if your traffic shows up in the ASP drop capture:
ASA# show capture drop
If you see the traffic in the drop capture, that means it was dropped by one of the reasons shown in the output of 'show asp-drop'. If this is the case, you can tweak the capture by specifying a particular drop reason (just change the 'all' keyword to one of the drop reasons listed in
The traffic is likely being dropped due to a misconfiguration. If possible, please post a copy of your config and indicate what the source and destination IP addresses and port numbers are and we'll be glad to help.
Hope that helps.
syjeon Sat, 03/14/2009 - 08:34
firewall transparent
hostname Attack
domain-name default.domain.invalid
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
no nameif
no security-level
interface Management0/0
no nameif
no security-level
ftp mode passive
access-list from_out extended deny ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
access-group from_out in interface outside
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username cisco password 3USUcOPFUiMCO4Jk encrypted
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh outside
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
I attached the configuration regarding your request.
I just a simple transparent configuration
the attack is located in asa inside area, and vicim located in asa outside.
our mission is that the attack's ddos traffic must be forwad to victim through transparent ASA
Regarding your opinion. the asa dropped are some of reason? if so, How can I disable the drop policy? Is it a configurable?
