RME Support for C2950G
xayavongp
I have LMS 2.6.1 with RME 4.0.6
For some reason I do not have the device support for Cisco 2950G. Can anybody pinpoint a package that will have this. I think things got screwed up somehow when I was upgrading, c2950 OID: 1.3.6.1.4.1.9.1.429
Joe Clarke
This switch is supported in RME 4.0.6 Cat2900XL package version 2.0.
I only see Cat2900XL package version up to 1.7.3, which I installed.
Does this mean I have to take RME to 4.1.1 to get the version 2.0 ?
No, there is a Cat2900XL package for RME 4.0.6. It sounds like your RME package repository is damaged. We see this a lot on Windows when there are certain things not done prior to installation:
* Set the TEMP and TMP environment variables to short values (e.g. C:
\WINDOWS\TEMP).
* Disable anti-virus and security software.
* Set Windows Data Execution Protection to be active for essential
windows files only.
* Login on the server's console as a local Administrator.
* Install from locally mounted original media.
TAC can offer some options for recovery. FYI, the Cat2900XL package should have been installed as part of RME 4.0.6.
