Unified Unity Questions
Is there a place on cisco.com to check if a particular patch/rollup is considered stable in a Unified VM environment. In my case, the Exchange Server is separate from Unity, but I don't want to break anything or cause issues when applying patches to my Exchange Server. I've always rebooted Unity after applying changes to Exchange, is this necessary?
Specifically, I want to apply Exchange 2007 SP1 Rollup 6 to my E-mail Server and want to know if this will cause any issues or if I should also be updating my Unity Server at the same time.
Thanks for any advice
Jaime Valencia Thu, 03/12/2009 - 12:00
  • Cisco Employee,
  • Hall of Fame,
    2011
no, you can install only the applicable updates on each server or just install updates on 1 server, your choice
java
if this helps, please rate
