Ad-Hoc Conferencing
Mar 12th, 2009
I've setup Ad-Hoc conferencing on a 2811 running 12.4(15)T8 with CME Using phone 1 I call phone 2 and then on phone 1 I place phone 2 on hold. Then I make a new call from phone 1 to phone 3. At that point I press conference on phone 1 and phone 2 and 3 are joined in a conference and phone 1 shows that it is connected to the extension that I have defined as the conference extension. However, I hear a busy signal on phone 1. Phones 2 and 3 can communicate back and forth just fine, but phone 1 doesn't become part of the conference. Phone 1 and 2 are on the same CME and phone 3 is on another phone system that communicates via H323. The conferencing is setup as hardware on the 2811 and I have enough PVDM2 resources to allow 6 sessions. I don't understand why phone 1 doesn't become part of the conference.
Paolo Bevilacqua Thu, 03/12/2009 - 11:46
Hi, once you configure HW conferencing, ad-hoc stops working. My recommendation is that patiently you go over the config examples in the manual to find a possible mistake.
rob.huffman Fri, 03/13/2009 - 05:46
Hi Brandon,
Just a comment here on the methods used by the phone user to setup the Conference. This is normally done this way;
Phone 1 calls Phone 2
Phone 2 answers
Phone 1 Presses Conference Button
Phone 1 calls Phone 3
Phone 3 answers
Phone 1 Presses Conference Button a second time and all three calls are Conferenced together.
Just a thought :)
brandon_leiker Fri, 03/13/2009 - 06:07
Thanks for the response Rob. I've tried that method as well and the same thing happens.
Chris Deren Sun, 03/15/2009 - 07:13
Are you using hardware or software conferencing here?
With CME software conferencing allows only for 3 parties, with hardware you can have up to 8.
If you are using hardware conferencing the most common ommision is the creation of conference ephone-dns, make sure you create these as described in the admin guide.
