VWIC2-1MFT-T1/E1 configuragion on UC520
Mar 12th, 2009
we just purchased an VWIC2-1MFT-T1/E1 card trying to look for any guies that would describe
how to install it and configure it.
We will be setting up a T1 ISDN PRI connection with our Avaya PBX.
we have an Idea of the configuration on the Avaya PBX side, but have no idea
about the configuration on the UC520 side.
Can anyone provide any helpfull feedback?
Steven Smith Thu, 03/12/2009 - 12:30
  • Gold, 750 points or more
CCA provides configuration options for T1's.  Here are some config guides that explain some of what CCA will be doing.
http://www.cisco.com/en/US/docs/routers/access/1700/software/feature/gui...
Those are the options on how to configure it in CLI.  If you let me know how you are configuring the Avaya side, I can help with configuring the UC520 side.
Steven
JMadrugaADM Thu, 03/12/2009 - 14:46
Hi Steven, thanks for your support.
We are planning to configure the Avaya with an ISDN T1 PRI connection to the UC520
we will crate a trunk type isdn-pri on the avaya side using an TN464 F DS1 card with 32 channels.
I have attached as cisco document I found with a configuration that I think will apply to my enviroment.
I'm just not sure abou the uc520 side.
Please take a look and let me know.
Marcos Hernandez Thu, 03/12/2009 - 14:54
  • Blue, 1500 points or more
The commands is this document should help you, just bear in mind that CLI is required (CCA won't be used).
Marcos
Steven Smith Thu, 03/12/2009 - 16:45
I am not sure about the 32 channels, 23 would probably work fine :)  The UC500 supports 1 PRI.
In the document that is there, you will see somethings that are important.
isdn switch-type primary-ni
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-10,24 nfas_d primary nfas_int 0 nfas_group 0
interface Serial0/1
no ip address
no ip mroute-cache
shutdown
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn T306 60000
no cdp enable
voice-port 1/0:23
dial-peer voice 29 pots
destination-pattern 2...
direct-inward-dial
port 1/0:23
prefix 2
This is going to be hard to implement if you don't use CCA.  The dial peer configuration and translations rules that you will want to use are likely to be difficult.
You could setup a full PRI with CCA using Primary NI on the link and change the timeslots.  If the Lucent can do that, this could be much simpler.
Steven
JMadrugaADM Tue, 03/17/2009 - 12:58
Hi Steve, I'm having a really hard time getting the UC520 to talk to the Avaya PBX. I'm confirming the settings on the Avaya side, but on the UC520 side I have
some doubts. I used the CCA as you suggested and set the switch type as primary NI.
Show run
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-22,24
Interface Serial 0/2/0:23
no ip address
encapsulation hdlc
isdn sending-complete
no cdp enable
voice-port 0/2/0:23
Steven Smith Tue, 03/17/2009 - 13:07
Can you do a show controller t1 and a show int serial0/2/0?
Also, a debug isdn q921 would be useful.
Steven
