BGP with VRF-Lite
Mar 12th, 2009
I have two Catalyst 6500 running BGP between VRF instances. I have IOS 12.2(33)SXH3 on both devices.
Everythings works well, prefixes are exchanged as designed. The only problem I have is that I don't find the right command to see the BGP TCP session state between both Catalyst. The command "show ip bgp summary" does not display anything between devices becaus I don't use the global plane. So, how can I see the same information for each VRF ?
Here is my configuration of one Catalyst:
router bgp 65372
no synchronization
bgp log-neighbor-changes
timers bgp 3 9
no auto-summary
address-family ipv4 vrf FR01RT08
no synchronization
neighbor 10.56.3.29 remote-as 65116
neighbor 10.56.3.29 description * CH01RT07 - Security Z4
neighbor 10.56.3.29 password 7 00331B07107E07150A
neighbor 10.56.3.29 activate
network 10.56.25.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf FR01RT02
no synchronization
neighbor 10.56.3.25 remote-as 65116
neighbor 10.56.3.25 description * CH01RT01 - Security Z3
neighbor 10.56.3.25 password 7 01240E054F2E0A1C24
neighbor 10.56.3.25 activate
network 10.56.21.0 mask 255.255.255.0
network 10.56.22.0 mask 255.255.255.0
network 10.56.23.0 mask 255.255.255.0
network 10.56.24.0 mask 255.255.255.0
exit-address-family
Thank you for any help
Yves
Giuseppe Larosa Thu, 03/12/2009 - 14:43
  • Hall of Fame,
    Founding Member
Hello Yves,
you can use
sh ip bgp vpnv4 all summary to get information about vpnv4 and VRF based BGP sessions
note: this release should support also vpnv6 so you need to type the whole keyword (we have almost the same release on several C6500)
Hope to help
Giuseppe
