In Linux-based UCM5.X /6.x, any command could verify DVD-ROM working ?
Mar 12th, 2009
Hello all,
I gonna replace DVD-ROM on UCM5.X server.
Is any "show" "list" etc command that could be run to verify if replacment DVD-ROM is working not?
Or do you have other way to check ?
Ethan
gogasca Fri, 03/13/2009 - 00:40
try show tech system
or try to burn a firmware upgrade use os and select local dvd as source instead of ftp/sftp that may be the best way to test it.
ethanenning Fri, 03/13/2009 - 07:50
thanks for your reply,GONZALO.
From" show tech system", I could see information below regarding DVDROM.
(I haven't replace the DVDROM yet)
cdrom 32896 0 [ide-cd]
class: CDROM
bus: IDE
detached: 0
device: hda
driver: ignore
desc: "HL-DT-STDVD-ROM GDR-D10N"
My question is:
1. Do you see anything suspected? Is this DVD really defective?
2. If I will test it with " firmware upgrade use os" DVD, do you mean that I need to click " upgrade ..." through UCM admin webpage? any detailed steps?
Thanks again,
Ethan
