Outgoing Call Failure
Answered Question
Mar 12th, 2009
I recently upgraded to UCM 7.0 from CM 4.1.3. After the upgrade I have been noticing a various phone numbers are flagged as international when they are processed by the h323 gateway. It seems to be relative to a particular area code. All of these calls that fail are national.
1402035: Mar 12 15:39:08.008 CST: ISDN Se1/0:23 Q931: isdn_parser_map_lkup: overriding plan/type for XXXXXXXXXX, isdn/national to isdn/international
1402036: Mar 12 15:39:08.012 CST: ISDN Se1/0:23 Q931: isdn_parser_map_lkup: overriding plan/type for XXXXXXXXXX, isdn/national to isdn/international
1402037: Mar 12 15:39:08.020 CST: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x744C
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9818398
Exclusive, Interface 1, Channel 24
Calling Party Number i = 0x2181, 'XXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x91, 'XXXXXXXXXX'
Plan:ISDN, Type:International
1402038: Mar 12 15:39:08.068 CST: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xF44C
Correct Answer by gogasca about 8 years 4 months ago
do u have a rule defined in the serial interface for this T1 PRI?
like isdn map ?
http://www.cisco.com/en/US/docs/ios/12_3t/dial/command/reference/dia_i2gt.html#wp1212108
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Thu, 03/12/2009 - 23:09
  • Green, 3000 points or more
like isdn map ?
joel.salminen Fri, 03/13/2009 - 07:35
Thanks for the information. It does work to force the isdn type to national. Any idea why this particular area code gets flagged as international? Here's my serial config:
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn map address 011* plan isdn type international
isdn map address 770* plan isdn type national
no isdn outgoing ie redirecting-number
no isdn incoming alerting add-PI
isdn nsf-service megacom
no cdp enable
