VPN router question passthrough
Mar 13th, 2009
Hello i have question about VPN passthrough i looking for some router with 3DES passthrough about 20Mbps.
In for example RVL200 i cannot find this parametr.
Regards Tomas
Steven DiStefano Sun, 03/15/2009 - 18:13
look on the gui tab called IPSec VPN...there should be a sub tab called "VPN Pass Through"
• VPN pass-through of Point-to-Point Tunneling Protocol (PPTP), Layer 2 Tunneling Protocol (L2TP), IPsec should be supported.
just remember the RVL200 supports 5 SSL tunnels and only 1 IPSec tunnel....  Comparison here...
Tomas Chott Mon, 03/16/2009 - 01:28
Hello Steve,
sorry for my english i means throughput of VPN, end user need throughput about 20Mbps in IPSec VPN with 3DES encryption.
Steven DiStefano Mon, 03/16/2009 - 04:41
I would not use a RVL200 in that case.  I dont think it will do 20mbps.  More like 14mbps.
I would use RV042 which has 60mbps VPN throughput, perhaps a bit less with 3des as I am not sutre what the operational profile used to determine performance numbers.  RV082 is advertised at 90 mbps as an FYI....
Tomas Chott Mon, 03/16/2009 - 06:37
OK, very good
and have you some table with this parameters for all router?
