12.2(50)SE Bug ?
Mar 13th, 2009
Not sure if this is a bug or a new feature ?
switchname(config)#enable secret 5 XXXXXXXXXXXXXX (encrypted password)
ERROR: The secret you entered is not a valid encrypted secret.
To enter an UNENCRYPTED secret, do not specify type 5 encryption.
When you properly enter an UNENCRYPTED secret, it will be encrypted.
Hope that this is a bug, but have anybody else a fix for this problem ?
cut & paste of old config doen't work any longer. :-(
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 03/13/2009 - 03:22
  • Hall of Fame,
    Founding Member
Hello Roar,
the message says to use
enable secret
I would so and I would leave to the device to create the encrypted version of the secret
these are the options
enable secret ?
0 Specifies an UNENCRYPTED password will follow
5 Specifies an ENCRYPTED secret will follow
LINE The UNENCRYPTED (cleartext) 'enable' secret
Hope to help
Giuseppe
Leo Laohoo Sun, 03/15/2009 - 18:00
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This is probably an "undocumented feature". I can't even see this command anymore in the 12.2(50)SE Switch Command Reference.
Typing the enable secret and the appliance will automatically encrypt it event though the "no service password-encrypt" is available. See below:
enable secret 5 $1$TZVm$SSMOghMN0RymiQKxNfmUC.
enable password juniper
Not good.
bretjaquish@hot... Fri, 05/01/2009 - 09:34
  • Bronze, 100 points or more
Service password-encryption has nothing to do with any "secret" passwords. They are automatically shown hashed MD5 output.
Service password-encryption only encrypts clear text passwords utilizing the "password 7" cipher (Vigenere). The passwords are not "encrypted". They are obfuscated to keep people from shoulder surfing.
b.julin Tue, 03/17/2009 - 07:11
You can get the crypts in by partial config file transfer via tftp/scp, and they still work from flash. It's just from the commandline that this is borked.
Leo Laohoo Tue, 03/17/2009 - 15:54
  • Hall of Fame,
    2017 LAN, Wireless
Hi Erich,
Thanks for point us to the right direction. +5
erik.briggs Fri, 05/01/2009 - 08:22
I've just confirmed that 12.2(50)SE1 has fixed this bug. I was finally able to paste in my encrypted secret passwords from the command-line. I'm glad I found this thread, because I was banging my head against the wall.
eborcher Fri, 05/01/2009 - 08:48
  • Cisco Employee,
Hello there,
I am not sure which version of IOS you're running but, this indeed looks like the bug I pointed out.
CSCsy24510 IOS no longer accepts encrypted password / secret
It is fixed in 12.2(50)SE1.
eborcher Fri, 05/01/2009 - 08:51
  • Cisco Employee,
Oops,
Still learning the NetPro tool. Glad to know that your problem is fixed.
Just to summarize, this bug is fixed in 12.2(50)SE1.
