peap authentication issue
Mar 13th, 2009
I have some problems with peap authentication. Here debug of my AP:
Mar 13 09:50:39 10.15.1.14 2370: *Mar 1 19:24:18.889: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
Mar 13 09:50:39 10.15.1.14 2371: *Mar 1 19:24:18.890: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to 001a.73ff.a214
Mar 13 09:50:39 10.15.1.14 2372: *Mar 1 19:24:18.890: dot11_auth_dot1x_send_id_req_to_client: Client 001a.73ff.a214 timer started for 30 seconds
Mar 13 09:51:03 10.15.1.14 2373: *Mar 1 19:24:43.549: dot11_auth_parse_client_pak: Received EAPOL packet from 001a.73ff.a214
Mar 13 09:51:03 10.15.1.14 2374: *Mar 1 19:24:43.549: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,EAP_START) for 001a.73ff.a214
Mar 13 09:51:03 10.15.1.14 2375: *Mar 1 19:24:43.549: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to 001a.73ff.a214
Mar 13 09:51:03 10.15.1.14 2376: *Mar 1 19:24:43.550: dot11_auth_dot1x_send_id_req_to_client: Client 001a.73ff.a214 timer started for 30 seconds
Mar 13 09:51:03 10.15.1.14 2377: *Mar 1 19:24:43.554: dot11_auth_parse_client_pak: Received EAPOL packet from 001a.73ff.a214
Mar 13 09:51:03 10.15.1.14 2378: *Mar 1 19:24:43.554: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,CLIENT_REPLY) for 001a.73ff.a214
Mar 13 09:51:04 10.15.1.14 2379: *Mar 1 19:24:43.554: dot11_auth_dot1x_send_response_to_server: Sending client 001a.73ff.a214 data to server
Mar 13 09:51:04 10.15.1.14 2380: *Mar 1 19:24:43.554: AAA/AUTHEN/PPP (00000159): Pick method list 'eap_methods'
Mar 13 09:51:04 10.15.1.14 2381: *Mar 1 19:24:43.554: dot11_auth_dot1x_send_response_to_server: Started timer server_timeout 60 seconds
Mar 13 09:51:25 10.15.1.14 2382: *Mar 1 19:25:05.371: dot11_auth_dot1x_parse_aaa_resp: Received server response: FAIL
Mar 13 09:51:25 10.15.1.14 2383: *Mar 1 19:25:05.371: dot11_auth_dot1x_parse_aaa_resp: found eap pak in server response
Mar 13 09:51:25 10.15.1.14 2384: *Mar 1 19:25:05.372: Client 001a.73ff.a214 failed: EAP reason 1
Mar 13 09:51:25 10.15.1.14 2385: *Mar 1 19:25:05.372: dot11_auth_dot1x_parse_aaa_resp: Failed client 001a.73ff.a214 with aaa_req_status_detail 1
Mar 13 09:51:25 10.15.1.14 2386: *Mar 1 19:25:05.372: dot11_auth_dot1x_run_rfsm: Executing Action(SERVER_WAIT,SERVER_FAIL) for 001a.73ff.a214
Mar 13 09:51:25 10.15.1.14 2387: *Mar 1 19:25:05.372: dot11_auth_dot1x_send_response_to_client: Forwarding server message to client 001a.73ff.a214
Mar 13 09:51:25 10.15.1.14 2388: *Mar 1 19:25:05.373: dot11_auth_dot1x_send_response_to_client: Started timer client_timeout 30 seconds
Mar 13 09:51:26 10.15.1.14 2389: *Mar 1 19:25:05.373: dot11_auth_dot1x_send_client_fail: Authentication failed for 001a.73ff.a214
Mar 13 09:51:26 10.15.1.14 2390: *Mar 1 19:25:05.373: %DOT11-7-AUTH_FAILED: Station 001a.73ff.a214 Authentication failed
Mar 13 09:51:27 10.15.1.14 2391: *Mar 1 19:25:06.611: AAA/BIND(0000015A): Bind i/f
In IAS log I can find requests and and access is permitted.
What is the problem?
Thank you for your help!
Trending Topics - Security & Network
