Racking
Mar 13th, 2009
I've just deployed 2 C160's in Cluster. All is good
BUT
I have IBM enterprise racking and the racks have round holes !
Does any one know what happened to the Round hole Racking Kits ?
If not then I believe the hardware is Dell based thus what Dell Kit would work ?
I'm going to Order some Dell Rack Rail Kits to see, I'm happy to post the results.
regards
Douglas Hardison Fri, 03/20/2009 - 14:03
  • Cisco Employee,
You can always contact Customer Support and explain that your rail kit you received with your IronPorts does not match your racks.
They'll do their best to send you a set that is compatible for your setup.
-whardison
chaicka_ironport Mon, 03/23/2009 - 08:28
IronPort Email Security boxes should be Dell-servers for the hardware, thus the rack mounting kit should also be based on Dell specs.
