Cisco 877 pure bridge mode
Answered Question
I need to configure my Cisco877 just in bridge mode between ATM interface and interface VLAN1 so my PC would get public ISP IP address. I think this is done just setting my windows xp network interface for DHCP client. Could anyone send me or post this configuration file?
Thanks a lot!!!
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
Hello Adis,
it should take an ip address by DHCP to give your PC a chance to telnet successfully.
You have ip routing disabled so the router can behave just as a PC.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 03/13/2009 - 03:26
  • Hall of Fame,
    Founding Member
Hello Seba,
check what the ISP is giving you: if it is PPPoE you need a PPPoE client on your PC instead of DHCP
note: I've linked a document in the cisco web site
Hope to help
Giuseppe
Giuseppe Larosa Fri, 03/13/2009 - 03:56
  • Hall of Fame,
    Founding Member
Hello Seba,
>> No, it is not PPPoE o PPPoA.
then you need DHCP on the PC indeed
the configuration is fine because bridging doesn't care of upper layer protocols
Hope to help
Giuseppe
It works!
I tried this configuration this afternoon and it worked. I also defined DHCP client on my PC network card.
You can have a look at it:
Router#sh running-config
Building configuration...
Current configuration : 903 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
archive
log config
hidekeys
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc x/x
encapsulation x
dsl operating-mode x
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Thanks a lot for your help!
Adis
Giuseppe Larosa Sun, 03/15/2009 - 01:22
  • Hall of Fame,
    Founding Member
Hello Adis,
nice news it worked
be aware that in this way you have configured the router as a bridge and you can access it only via console.
Hope to help
Giuseppe
Correct Answer
Giuseppe Larosa Mon, 03/16/2009 - 08:15
  • Hall of Fame,
    Founding Member
Hello Adis,
Hope to help
Giuseppe
