SCE recieve only mode with switch
Answered Question
Mar 13th, 2009
I have to test an SCE 4xGBe in the recieve only mode. I am not going to use an optical splitter to connect my device i will use a switch with gbe connections and the span function to redirect traffic to the gbe of the sce.
could any one explain the general procedure to do that.
Correct Answer by jasmina27s about 8 years 2 months ago
You need two SPAN destination ports on the switch. One port is connected to the SUB port of SCE, and another is connected to the NET port of SCE (You need SCE to receive SPAN-ed traffic in appropriate direction).
You need two SPAN sessions.
You need to select one port on the switch where a group of Subscribers is connected and use it as the source port of SPAN sessions (both access or trunk port can be monitored).
Configuration will look something like following:
monitor session 1 source interface rx
monitor session 1 destination interface encapsulation replicate
monitor session 2 source interface tx
monitor session 2 destination interface encapsulation replicate
If you use trunk source port, you may need "encapsulation replicate" part in the above command.
I hope this helps :)
Best regards,
Jasmina
Overall Rating: 5 (1 ratings)
dennischolmes Fri, 03/13/2009 - 04:28
  • Gold, 750 points or more
Any particular reason this is in the wireless forum?
Correct Answer
jasmina27s Wed, 03/25/2009 - 05:53
Best regards,
Jasmina
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
