Multiple Dhcp Pool for multiple vlan
Answered Question
Mar 13th, 2009
Respected All ,
I have to configure one switch of any model as DHCP server , and in my LAN there are five floor , i have created five vlan for every floor , now i want to configure that switch as DHCP Server which will server each floor with each vlan IP schema respectivly.
Amit kulshreshta
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Amit,
if the device is going to be a DHCP server you need to configure multiple dhcp pools
like
ip dhcp excluded-address 10.110.224.129 10.110.224.132
ip dhcp excluded-address 10.110.224.145
ip dhcp pool DATA
network 10.110.224.128 255.255.255.240
default-router 10.110.224.129
dns-server 10.98.112.32 10.55.0.32
netbios-name-server 10.52.64.37 10.24.128.151
lease 0 1
ip dhcp pool VOICE
network 10.110.224.144 255.255.255.248
default-router 10.110.224.145
option 150 ip 10.98.67.5 10.55.61.4
lease 0 1
each pool will use the ip addresses of each vlan.
By receiving a request on vlan x the device will know from what pool to take the ip address to assign to the client
if other L3 devices exist they need the ip helper address configuration as explained by Adam on client vlan sides
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 03/13/2009 - 03:53
  • Hall of Fame,
    Founding Member
Hello Amit,
like
ip dhcp pool DATA
lease 0 1
ip dhcp pool VOICE
lease 0 1
Hope to help
Giuseppe
