Unity express Editor
Mar 13th, 2009
I just installed Unity express 7 and the voice mail works fine. I am making an IVR using CUE but to my surprise I don't see a way to debug the program. This was possible in previous releases. So now I am making more or less blindly a program and hope it works.
Is there a way to debug my program using CUE 7?
thanks,
JH
Matthew Guerrera Fri, 03/13/2009 - 15:34
To my surprise I just found the same thing... I just installed CUE Editor 7.0.1 and there is no debug on the menu.
It appears in the 7.0.1 CUE docs there is a debug menu. It's not a show stopper, but a nice feature to troubleshoot large scripts.
Matt
j.huizinga Tue, 03/17/2009 - 00:25
Hi Matt,
You are right in the manual of CUE 7 it shows the debug menu, but it is not there.
I am using logging on the Unity express which helps a little. But Cisco should put the debug ASAP in CUE 7
regards,
Jan
