Web trigger issue
Mar 13th, 2009
I have two servers in HA
express v7 sr1
10.0.0.1 - master
10.0.0.2 - slave
I have a web page the points to an http trigger on my ipcc express servers and passes some values
http://10.0.0.1:8080/promptmgr?CCName=1&P_No=Welcome_Msg&CC=690&Action=1
This all works fine when 10.0.0.1 is the master but if 10.0.0.2 is the master I just get a black page, in older versions the the master would fwd the request from the web page to the new master, but its not doing that now, is there a way round this?
ccie6269 Wed, 05/20/2009 - 05:57
Check out this bug. It might be your issue.
CSCsy58015 Bug Details
Http trigger does not work when failover occurs
Symptom:
http trigger, from where they are passing the parameters to the script. It works fine when the Node1 is mater... if it fail over to Node2 then the information is not passed to the script.
Conditions:
HA setup and if it failover to 2nd Node.
Workaround:
Make changes to asp/http file where they have the ip address of the Node1 to Node2
1st Found-In
5.0(1)SR1
7.0(1)SR1
Fixed-In
7.0(1.2.93)
Jim
