vpnv4 connected routers not cummunicating
Answered Question
Mar 13th, 2009
I have 4 routers connected as per sketch below, I can ping my directly connected VRF's from both PE's(R2 can ping R1 and R3 can also ping R4). My PE's cannot ping each other.
both these PE's are running BGP 1000
then R4 BGP 65001 and R1 BGP 6500
(CE)R1 - R2(PE) -- (PE)R3 - R4(CE)
R2(PE)
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface ATM3/0.100 point-to-point
ip address 165.148.120.2 255.255.255.252
no atm enable-ilmi-trap
mpls label protocol ldp
mpls ip
pvc 1/100
encapsulation aal5snap
address-family vpnv4
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community both
exit-address-family
R3(PE)
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface ATM1/0.100 point-to-point
ip address 165.148.120.1 255.255.255.252
mpls ip
pvc 1/100
neighbor 4.4.4.4 activate
neighbor 4.4.4.4 send-community both
neighbor 4.4.4.4 next-hop-self
exit-address-family
I suspect the problem is with my MPLS cloud(vpnv4).
Correct Answer by Harold Ritter about 8 years 1 month ago
Lawrence,
When you say "PEs cannot ping each other", do you mean they can't ping each other directly connected interface address (atm1/0.100) or their respective loopback addresses?
Do you have a routing protocol running between the two PEs? If so, do see the neighbors loopback address?
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Fri, 03/13/2009 - 06:13
  • Cisco Employee,
Lawrence,
