Tunnel config
Mar 13th, 2009
I configured Tunnel, but i am not able to ping my remote tunnel ip.ie 10.10.1.2 and vice-versa.
On Mumbai Router
inter fa 0/0
ip address 10.5.2.2 255.255.255.252
des "connected to WAN"
inter tunnel 0
ip address 10.10.1.1 255.255.255.252
tunnel source 10.5.2.2
tunnel destination 10.5.2.90
ip route 10.10.1.0 255.255.255.252 10.5.2.1
On Pune Router
inter fa 0/0
ip address 10.5.2.90 255.255.255.252
inter tunnel 0
ip address 10.10.1.2 255.255.255.252
tunnel source 10.5.2.89
tunnel destination 10.5.2.2
ip route 10.10.1.0 255.255.255.252 10.5.2.89
Harold Ritter Fri, 03/13/2009 - 06:04
Arjun,
The source address of the tunnel interface on Pune should be the fa0/0 address 10.5.2.90 rather than 10.5.2.89.
Do you have a route on Mumbai to reach 10.5.2.90 ans inversely a route on Pune to reach 10.5.2.2.
Also, you do not need the static routes for 10.10.1.0/30 as these routes will be installed as a connected routes because of the tunnel interface.
arjunsawant Sun, 03/15/2009 - 20:51
Thanx a Lot..
Now i am able to ping my remote tunnel IP.I have one more query.
I have one more backup ISP to Pune using BGP.I want redundancy.If my 1st ISP fail, 2nd will work.
can I create a second tunnel for that.
Currently for 1st ISP i am using static route.Is it possible to use same loopback address for both ISP.
I am very greatful to U.
Harold Ritter Tue, 03/17/2009 - 06:05
Arjun,
Could you please explain why you would need a GRE tunnel to your primary or backup ISP.
arjunsawant Wed, 03/18/2009 - 04:34
Thanx...
I need autofailover to my both ISP.
Pune user should access Mumbai via 2nd ISP if my 1st ISP fail.
Thax Again..
Harold Ritter Wed, 03/18/2009 - 05:57
Arjun,
And why do you need GRE tunnels to do that? Can't you do it without GRE? A diagram might be useful.
arjunsawant Thu, 03/19/2009 - 04:57
Thanx a lot..
I can do this without GRE.
My priority is Autofailover to my both ISP.For REL(MPLS VPN) i am using BGP and for VSNL (MPLS VPN) using static routes on my Mumbai router.
On Pune router i am using static routes for primary (REL).When REL down i manually change that routes toward VSNL.
Is there any way to autoswitchover route like using metric.
Pls find the attachment.
arjunsawant Thu, 03/19/2009 - 20:26
Thax for u'r suggestion..
But on pune router i am not using BGP.There is a static route for ISP.
Is there any way..?
