RME Config Archive Polling
I have rme 4.1.1 on solaris 10 running.
I set up config collection setting for periodic polling on a daly and for perodic colletion on a weekly basis. Perodic collection jobs fine without any errors. Perodic polling jobs failed every day. ArchivePoller shows 163 device success and 3 failed. Error is always the
same. See attachment. Strange is, in most jobs are every day different devices.
Appreciate every hint.
HR
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 03/13/2009 - 07:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This error points to a problem fetching the vlan.dat from this switch. In order for RME to fetch vlan.dat, it must be able to login to the device using either telnet or SSH, and TFTP the vlan.dat file back to the RME server. The error indicates that the enable credential in DCR is incorrect for this device. Verify the DCR credentials are correct. If you are using telnet, get a sniffer trace of all telnet traffic to this device when archive polling is running. That should illustrate the problem more clearly.
