Passthrough Public IPs / NAT Exempt
Answered Question
Mar 13th, 2009
Here is my scenario. I have a /26 from my provider. I have a server that I want behind the firewall but must have a public IP on it and can't be nat'd. I have carved a /30 out of my /26 and have nat exempted it inbound from the outside and outbound from the inside. I have set up routing on the inside and can ping the server on it's public ip from the firewall but can not get out to the internet. Is what I want do even possible? In the past I have done similar but had the provider give me another public block to route through the firewall and that works great. I fear that may be the solution here.
Thanks in advance!
Correct Answer by Collin Clark about 8 years 4 months ago
Sorry I don't have an ASA to test with, but can't you static it?
static (inside,outside) 75.50.95.73 75.50.95.73 netmask 255.255.255.255
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 03/13/2009 - 06:55
  • Purple, 4500 points or more
mloraditch Fri, 03/13/2009 - 07:10
Awesome that worked. Never even crossed my mind.
Thanks!!!
