Installing SSL Anyconnect
Mar 13th, 2009
Tryed to install SSl Anyconnect and received a message "VPN Client agent was unable to create the interprocess communication depot".
That is as far as I can get.
Ivan Martinon Fri, 03/13/2009 - 11:56
  • Cisco Employee,
Do you have any security suite AV or something running on the background? like McAfee Norton or so? if you do, can you disable those?
brocksolutions Thu, 03/19/2009 - 19:40
we have the same problem, on Lenovo W500 64 bit vista.
Problem only exisit after the machine is fully patched. Vista out of the box (from Lenovo) then install the client prior to patching is ok.
Did you get it to work ?
