Access to ASDM using Windows Vista 64bit.
Jagdeep Gambhir Fri, 03/13/2009 - 10:20
ASDM is not a 64-bit application. I don't think that it is going to work.
Did you try 32 bit OS ?
Hello Andrea,
I run ASDM on VISTA 64, but there is a trick, make a shortcut to the ASDM launcher. right click and select properties, on the compatibility tab check off run program in compatibility mode, then select xp service pack 2 from the list. You should be good to do. Make sure you have the latest and greatest ASDM as there is also java issues you may run into.
