share line
Answered Question
Mar 13th, 2009
I have CCM 4.1.3.
I have a share line on 2 phones and I want that the phone #2 can not pick up the line when it rings. I just want the line appearance.
It's possible?
Correct Answer by Rob Huffman about 7 years 11 months ago
Hi JP,
This is not possible in CCM 4.1(3). With the new 6.x and 7.x releases you can use BLF (Busy Lamp Field) to monitor the "Line in Use" type scenario, but in the earleir versions the best you can do is to disable the Ringer on the Shared Line for Phone #2.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 03/13/2009 - 07:46
Hi JP,
Hope this helps!
Rob
