WS-C3560-8PC-S routing performance and capability
Answered Question
Mar 13th, 2009
All,
What is the routing performance of WS-C3560-8PC-S? Can I get 100Mbps out of the interface?
Correct Answer by Edison Ortiz about 8 years 3 months ago
You are right, but you can take the information provided on this page:
http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_models_comparison.html
and come up with the numbers from the previous page.
Based on the page above, the 8port switch produces 2.7 Mpps which based on my calculations taken from the 2 models listed in the initial link rates about 3.6Gbps..
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 03/13/2009 - 08:23
  • Hall of Fame,
    Founding Member
Mohamad,
That's incorrect !
The link you've posted is related to the Advanced IP Services feature set, not the hardware itself.
__
Edison.
yuhuiyao Fri, 03/13/2009 - 08:27
I have read that before. It did not mention any performance about routing. I am wondering if routing can have the same performance as swtiching.
Edison Ortiz Fri, 03/13/2009 - 08:30
  • Hall of Fame,
    Founding Member
See the column L2/L3 ? 3560 indicates L3 so those stats where measure with routing involved.
HTH,
__
Edison.
yuhuiyao Fri, 03/13/2009 - 08:36
There is nothing about C3560-8PC, the 8 porter I am looking for.
Correct Answer
Edison Ortiz Fri, 03/13/2009 - 08:59
  • Hall of Fame,
    Founding Member
Joseph W. Doherty Fri, 03/13/2009 - 17:14
Depending on which specs you examine, you might be able to obtain full wire rate from all ports (for either L2/L3). If true, answer to your question is yes. If not true, very likely switch's L3 performance is (much) more than 100 Mbps.
PS:
Where the specs conflict:
Table 2 in http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html shows, for performance, 32 Gbps forwarding bandwidth (all 3560s?) and 2.7 Mpps (Cisco Catalyst 3560-8PC), but in Edison's first reference, although the 8 port 3560 isn't listed, other 10/100 3560s are noted with less than 32 Gbps.
The Mpps rating, 2.7 Mpp, is what's needed for wire speed, only whether 3.6 Gbps fabric bandwidth is provided is unclear.
