ASA active active
Mar 13th, 2009
Hello, I was thinking to use ASA5520 in Active Active mode but I have a doubt about how it work.
As from my readings the context that is in a falover group can process traffic only in the unit where this context is active. Therefore for this context there is no load-balancing. To acieve load balancing you have to create 2nd context and set it as active on the secondary unit. is that correct ?
JamesLuther Fri, 03/13/2009 - 15:44
Your statement is correct. There is no load balanciong for a single context.
Active active is a manual configuration making half your contexts active on one ASA and the half active on ther other ASA.
