QoS, NBAR, and NAT - Help
Mar 13th, 2009
When using NAT, I understand that the translation is done BEFORE QoS is applied for inbound-to-outbound traffic. If this is correct, how would an ACL look if I wanted to restrict one host on the inside from going out a certain port?
Public IP:
Private IP:
If a service policy is applied as output on the public interface, then QoS would match on the address, but if I wanted to restrict cnn.com, I would restrict everyone behind that address. Is there a way to restrict just the one host?
I've been using NBAR and I can't get anything to match, for whatever reason, so I'm wondering if it has something to do with NAT. Does anyone have a good example of a config that is using NAT, NBAR, and blocking either whole websites or, better yet, mime types?
rpfinneran Mon, 04/13/2009 - 02:10
Use NBAR to mark the traffic. Then use an ACL blocking to any IP that has that marking.
So, just an example...
class-map match-any CNN
match protocol http url "*cnn.com*"
policy-map CONTROL-HTTP
class CNN
set ip dscp 1
ip access-list extended 110
permit ip host any dscp 1
ip access-list extended DROP
deny ip any any
interface lo200
desc *** My Black Hole ***
ip address
ip access-list DROP in
match ip address 110
set ip next-hop
interface Fa0/0 !(inside int here)
service-policy input CONTROL-HTTP
ip policy route-map BLACK-HOLE-HTTP
